akhilahmed
Adding additional constraints to the auto-generated constraints in Vivado IP integrator
I am trying to instantiate a microblaze and a UARTLite on ZCU104 and route UART signals to PMOD pins. To route these UART pins to the PMOD pins, I make the Tx and Rx pins as external (Right-click on pin and select "make external"). I want to add constraints only for these two pins and use the auto-generated constraints for the rest of the design. How do I do this?
If I add a new constraint file and specify constraints only for the Tx and Rx pins, I see that the other pins don't get constrained and lead to errors. Is there any easy way to use the auto-generated constraints for the microblaze and it's associated IPs, and user specified constraints for only a few pins?
Thanks!
kvasantr
Hello @akhilahmed
You don't need to write one more constraint files for this. Under generated IPI products of your IP design under sources -> you will find constraint and under that same file, you should mention these constraints.
can you share me the constraint file you have generated from the example design?
thank you
akhilahmed
Thank you for the solution. I will try that.
The constraints I want to add are as below:
set_property IOSTANDARD LVCMOS33 [get_ports rx_0]
set_property IOSTANDARD LVCMOS33 [get_ports tx_0]
set_property PACKAGE_PIN U7 [get_ports tx_0]
set_property PACKAGE_PIN W8 [get_ports rx_0]
set_property SLEW FAST [get_ports tx_0]
I got these written by using the GUI.
akhilahmed
But the generated files under Sources -> IP Sources -> Block Designs are all read-only.
Did you imply that I should add my constraint file here?
akhilahmed
The auto-generated constraint files are read-only. Is it recommended to change permissions of this generated file and add my constraints to it?
