Observer maty
Address assignment can only be done within the address range...
Hello, I'm fairly new to all of this. As far as I understand this project, the Microblaze and Zynq will sharing RAM. For this to work, I believe I need to set the offset address range for both processors to match, however every time I try to change it, I get this error message. Please help.
Observer maty
Re: Address assignment can only be done within the address range...
Update: I followed this solution, https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Vivado-Block-diagram-not-recognising-full-DDR-Memory-size/td-p/465764 and now in the Address Editor screen it does show processing_system7_0_HP0_DDR_LOWOCM at offset addresss 0x0000_0000, which is what I want. However it won't validate, it does not like being at address 0x0000_0000... No matter how hard I try.
This is the error message I am getting in the Tcl Console
CRITICAL WARNING: [#UNDEF] Address segment /processing_system7_0/Data/SEG_processing_system7_0_HP0_DDR_LOWOCM with base address : 0x00000000 and high address : 0x3fffffff is out of range for M_AXI_GP0. Valid range for M_AXI_GP0 is 0x40000000 - 0x7fffffff
CRITICAL WARNING: [BD 41-1288] Master segment </processing_system7_0/S_AXI_HP0/HP0_DDR_LOWOCM> in </processing_system7_0/Data> at <0x0000_0000 [ 1G ]> is illegal. This address exceeds the base address limitations <0x4000_0000 [ 1G ]> of the interface(s) </processing_system7_0/M_AXI_GP0> through which it is accessed by this address space.
