Archiving of project from tcl script hangs and eats up memory
I am having an issue when archiving from a tcl script. The following line is printed out and the archive process never completes.
"INFO:ProjectMgmt - Project Archive - Copying project files."
What is disturbing is that it seems to be in a loop while hanging in which it continually uses up more and more memory. I have seen this bug consume over 20 G before I killed the process. The memory is consumed by copying files over and over again into a /tmp folder it creates.
I am using ISE 14.1 on rehat linux 5.7.
Has anyone seen this before? Is there anyway to see what is actually going on inside this loop?
Andrew
Re: Archiving of project from tcl script hangs and eats up memory
I'm not sure exactly what is going on.  We have had a few similar reports where the archive is adding recursive directory structure to the tmp archive location which results in a path too long error and an apparent hang.
This happened with projects containing sub-project source types (EDK specifically).
Does the same problem happen when archving from the GUI?
You can see some of what is going on bysetting the XIL_PROJNAV_FLOW_DEBUG_LEVEL environment variable.  The following command can be used in the Tcl console to set it.
   set env(XIL_PROJNAV_FLOW_DEBUG_LEVEL) 34
What command do you use for the archive?
If you have not done so already, can you try a short absolute path (e.g. "project archive /temp/myarchive.zip")?
This issue seems to have mysteriously disappeared. I'll try your suggestion if it happens again.
It may have been related to this issue.
http://forums.xilinx.com/t5/Design-Entry/Process-properties-missing-when-generating-tcl-script/m-p/278908#M3517
Andrew
