Observer altameemi
Arithmetic Shift
Hi All
As Xilinx instruct in ISE language templates that operator "<<" to operate a left logical shift and this on "<<<" to operate a left Arithmetic shift. But when I used both of them, I got a logical shift in both cases. I use ISE 12.4. Is there some thing with my code.
I will be highly appreciated if some body guide.
alwayes ...
sh_result[31:16] <= sh_in >> 6;  //Do a logical shift
sh_result[31:16] <= sh_in >>> 6; // Should give an Arithmetic shift, but it doesn't (the result as in previous expression)
Professor
Professor
Re: Arithmetic Shift
Unless your variables are signed, then a logical shift and arithmetic shift
should give the same results.  Using signed logic is tricky in Verilog.
mixed operations tend to default to using unsigned arithmetic, rather
than the expected signed arithmetic.  How did you define sh_in?
-- Gabor
-- Gabor
Historian
Historian
gszakacs wrote:Using signed logic is tricky in Verilog.
-- Gabor
That's why Verilog is the best HDL ever invented, or that will ever be invented.
Observer altameemi
Hi Gabor
I have actually cheked the above operators (>> and >>>) individually. sh_in is the input data, which should be shifted. sh_in is provided from many registers located in a registers file. The supplied data was contain a 1 in MSB, which should refer to the sign bit, shouldn't it ? If not, how can I assign signed and unsigned binary patterns please?
Instructor
Instructor
From the Stuart Sutherland Verilog (2001) HDL Quick Reference Guide:
operator   example   description
  >>>      m >>> n   shift m right n-times; fill with value of sign bit if
                     expression is signed, otherwise fill with 0 (Verilog-2001)
   >>      m >> n    shift m right n-times and fill with zeros
If the variable being shifted is unsigned, the operator >> is entirely equivalent to the operator >>>.
Only if the data type of the variable being shifted is declared as signed.  If unsigned, an arithmetic right shift will fill with '0'.  You should re-read Gabor's post, I am merely repeating what Gabor has already written.
By the way, if you are interested in Verilog training or are interested in a Verilog book, Stuart Sutherland is an excellent instructor (and author).  I've taken his workshop.
-- Bob Elkind
SIGNATURE:
Summary:
Observer altameemi
Thank you very much for your detailed explanation guys.
Cheers
