Aurora v10 Vivado lab tools not available
I am using Vivado 2015.1. In the Aurora v10.0 manual (page 74, chapter 4), I saw that there is an option called "Vivado lab tools":
However, when I try to configure my Aurora core, I get this window that is missing this option (!):
I tried to scroll down, mark other options in case it appears, but nothing. Do you know if this is a bug or am I missing something?
Dimitris
Re: Aurora v10 Vivado lab tools not available
Looks like you are using the core in IPI.
The option is not available when you use the core in IPI(Block design) and only available with RTL projects.
Satish
Satish
Hello yenigal,
Yes I am using it in IPI mode, thanks for the info. It would be great if it was supported :)
Dimitris
