Auto infer IP VLNV Interface from System Verilog Interface
I am trying to find a way to make vivado packager auto infer the interface of a system verilog module.
The module has the interface declared and instanciated as a SV interface (with modports).
I can do this in verilog by adding the lines:
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 S_AXI AWADDR" *)
input wire [31 : 0] s_axi_awaddr;
But i cant figure out a way to do it in SV where the i/o is declared at the modport..
Is there any way ?
thanks!
Is there any way (via a directive or macro) , to make Vivado packager auto-infer the Interface when packaging a component
Re: Auto infer IP VLNV Interface from System Verilog Interface
This is IP flows (IPI) related issue hence moving it again to design entry board.
hemangd
