Newbie syllys
Axi Gpio help
Hello, i'm new to vivado. I need to communicate between ps and pl. My design has 2 input and 3 output (all 1 bit), so i thought to add 5 axi gpio of 1 bit (setting 3 all output and 2 all input in the option). I'm sure i can use only one axi gpio, how i create it? I'm confused because now i have to deal with input and output together. I set like this:
if it's ok how i draw connection?
Thanks for your help.
Newbie syllys
Re: Axi Gpio help
Hi! I still have the same question: it is possible to use only one axi gpio for more signals (each of 1 bit in my case)?
Voyager
Voyager
Re: Axi Gpio help
Let me introduce you to two indispensable built-ins within IP Integrator: Concat and Slice.
The above is an expansion of a 32-bit Status Register construction that I often use in designs. This particular Concat has 32, one-bit input ports, but each input port of Concat can actually be any width. The output port size of Concat is automatically determined by the IP by adding-up all of the input ports.
Concat groups individual bits and smaller buses together into larger buses. Slice extracts an individual bit or several bits (sub-buses) from a larger bus.
Using these two devices, you should be able to connect your two blocks together any way you wish.
-Joe G.
