[BD 41-1273] Error running propagate TCL procedure
can some one please explain why I'm getting the above error. The project was working fine. I then tried to add some new IP in Vivado 2015.2 block design. There was a problem with the IP so I deleted it. So net change should be nothing, but not so. After I added and deleted the IP I then get the attached error when I run validate. Any idea why? Any idea how I get back to a working design? I have tried resetting and regenerating the ouptput products.
Peter
Re: [BD 41-1273] Error running propagate TCL procedure
I have got rid of the errors by exiting Vivado without saving it. Opening it up again and re-validating and it works fine. Phew.
In Vivado 2014.2  IPI, a new check was introduced to make sure that tlast signal is connected when  a DMA is used in the design.
This error occurs if S2MM or MM2S are enabled and the connections are left floating
Thanks and Regards
Balkrishan
The VDMA doesn't have any of its output floating. See schematic
But in this particular case, the connections are all there, except the MM2S has been pulled external, see the screen shot
This is a bug with the tools and is fixed in 2014.3. In the mean time, you can workaorund the issue by editing the axi_dma_v7_1/bd/bd.tcl in the build area, comment out lines 63 to 91.
Thanks and Regards
Balkrishan
Doesn't look like a solution but a lucky day. Has anybody else anything more universal?
