teddywhy
Block Design with an IP having global defines
Dear Sir,
I am using Block Design but one of my IP has global defines.
Do I need to have same global defines when using Block Design ?
Teddy Wong.
Tags (2)
teddywhy
I have solved this problem by adding external defines to block design and ip package. Thanks.
vsrunga
Not exactly.
UG1118 says - After packaging Vivado tool treats global `include files as standard Verilog or Verilog Header files.
To package a design that uses global ‘include files, you must modify the HDL to place the
`include statement at the top of any Verilog source file that references content from another Verilog or Verilog header file.
teddywhy
To be exactly, this ip has different configurations according to different external defines.
It looks like external defines is needed in final block design, isn't it ?
vsrunga
Are you packaging  RTL(with defines) and using it as a custom IP long with other IPs whose configuration is based on those defines?
If yes, as other IPs don't have knowledge about those defines you should have them included..
teddywhy
