Advisor ronnywebers
Advisor
Block design keeps saying 'refresh IP catalog'
Using Vivado 2015.4
for some reason, the 'refresh IP catalog' in my block design window regularly 'pops-up', for no reason. When I hit refresh IP catalog, it runs but finds no differences or updates needed (which there aren't).
Is there any reason for this? Looks like a bug? On what basis does Vivado decide something (might have) has changed in the IP repo(s)>?
Re: Block design keeps saying 'refresh IP catalog'
@ronnywebers,
There are many existing CRs on this which seem to have been fixed.
You can try with Vivado 2016.2 or with 2016.3 (once it is released) and see if you get the same behaviour.
Nupur
update your vivado version to Vivado 2016.2 release. You may try with new project . It may your project got corrupted
Thanks and Regards
Balkrishan
Hi @ronnywebers,
There is an issue reported regarding "inconsistency on "refresh IP catalog"". Currently a CR is existing on this and is scheduled to be fixed in future Vivado versions.
Arpan
I see this every time I change directory in the tcl window.
@ronnywebers,
Nupur
Advisor ronnywebers
Advisor
@nupurs@balkris
I'd love to upgrade, but unfortunately I cannot upgradeas I'm in the middle of a project, and the consequences of upgrading would be too large.
I think the issue popped-up after I relocated a referred custom IP to another folder. I first deleted the IP from the block design, then removed it from the project repository settings. Then added the new location of the custom IP to the repository settings, and added the IP back to my block design. Since then my project starts randomly telling me I need to upgrade my IP - which is not the case.
I didn't dare to just 'relocate' the repository in the settings without removing the IP and adding it again. That doesn't seem to work well ...
Anyone an idea which file or what exactly triggers Vivado to say something has changed? Is it some specific file content, a file date, ... ?
I guess I can 'ignore' the upgrade request in case I know that my IP is up to date?
Advisor ronnywebers
Advisor
@nupurs@balkris
I disccovered at least 1 systematic way to trigger the 'refresh ip catalog' :
* after I open a (any) project, when I enter 'pwd' in the tcl command, the folder points to somewhere on my C: drive, but not to the current project folder
* if I enter a tcl command to switch to the current project directory, immediately a 'refresh ip catalog' appears. The command it this one :
cd [get_property DIRECTORY [current_project]]
there must be some relation between the project directory change and the triggering of 'refresh ip catalog', can you think of a way to avoid this?
