Visitor rafalh11
Bug causing vivado to crash on syntax error.
Vivado crashes during refresh hierarchy when there is unfinished variable declaration for a process inside generate.
Scholar pratham
Re: Bug causing vivado to crash on syntax error.
@rafalh11 CR#890756 filed on this.
-Pratham
Scholar pratham
@rafalh11 Yes, i could reproduce this issue.
I  will file a CR on this.
-Pratham
Scholar pratham
-Pratham
