dpaul24
Bus Interface property FREQ_HZ mismatch for a custom IP core and the Xilinx VTPG core
I am using Vivado 2018.1.
I have a block diagram where I am connecting the Xilinx VTPG IP core to a custom IP. This custom IP is nothing but a AXI4Lite master which configures the VTPG registers.
When I validate the block design I get the following error-
ERROR: [BD 41-237] Bus Interface property FREQ_HZ does not match between /v_tpg_0/s_axi_CTRL(150000000) and /axi4lite_m_w_0/axi4lite_m(100000000)
ERROR: [Common 17-39] 'validate_bd_design' failed due to earlier errors.
After a few searches took me to this AR - https://www.xilinx.com/support/answers/56610.html
As it says for all AXI clock ports made external, the default FREQ_HZ  is 100M. Now the VTPG input clock is supposed to be 150M and due to this frequency mismatch I am getting the above error.
Now I am looking for a way to specify or correct this FREQ_HZ for my aclk_150M_i. How can I do that?
Because, under Properties --> Config, I do not get an option to edit the FREQ_HZ parameter. Or have I made a mistake during packaging my IP (in this case, please also suggest what needs to be corrected).
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
dpaul24
@vsrunga,
I now have a synth project. Well many things had to be changed.
I had to change my axi4lite master RTL to VHDL from VHDL2008, else using 2018.1 I was getting some error messages.
I re-read the UG and after some tries could generate a clean custom IP when I packaged the complete project. Initially I was using the Directory option to package my IP (while I think this option should also work, I did not try it for lack of time).
Finally in the BD of the target project (where the IP was added) I had to change the FREQ_HQ parameter of the axi4lite 'interface definition' which connects the axi4lite master and the TPG IP core (thanks to Drsaab for pointing this out, I should have read the error msgs more carefully).
Well I am still learning the intricacies of Vivado BD, by hand-instantiation I could have achieved this target within 30min, here playing around with DB cost me 5 hours!
DrSAB
(1) Delete the slck_150M_i port.
(2) Create a new port; select the type to be Clock and the Frequency(MHz) field will be enabled for you to set the frequency.
(3) Connect this new port to the bd.
dpaul24
@DrSAB,
Thanks it works. But I still have the fundamental error message...
TCL Output:
save_bd_design
Wrote  : <C:/xil_tutorials/my_projects/hdmi_pass_vtpg/hdmi_pass_vtpg.srcs/sources_1/bd/hdmi_pass_vtpg/hdmi_pass_vtpg.bd>
Wrote  : <C:/xil_tutorials/my_projects/hdmi_pass_vtpg/hdmi_pass_vtpg.srcs/sources_1/bd/hdmi_pass_vtpg/ui/bd_cc0a773c.ui>
validate_bd_design
CRITICAL WARNING: [BD 41-1356] Address block </v_tpg_0/s_axi_CTRL/Reg> is not mapped into </axi4lite_m_w_0/axi4lite_m>. Please use Address Editor to either map or exclude it.
CRITICAL WARNING: [BD 41-967] AXI interface pin /axi4lite_m_w_0/axi4lite_m is not associated to any clock pin. It may not work correctly.
What about the Critical Warnings listed?
Is it related to the way I ma packaging the custom IP core?
Basically I have this Warning when I created the IP package, while combining the AXI4Lite signals....
And there was no way I could associate a clock....As you see from the SS below, I didn't get any list from where I could associate a clock for my AXI4Lite interface.
DrSAB
Go other way around. It is axi4lite_m which is set to 100MHz and not associated to a clock.
(1) Disconnect the clks wires; delete the sclk_150m port.
(2) Make axi4lite_m a port , set the type and clock frequency.
(3) Connect the VTPG clock.
This should help vivado resolve the FREQ_HZ property.
vsrunga
Do you have X_INTERFACE_INFO attribute in your vhd?  If not can you try adding it and see if Associate_Clocks shows options ?
attribute X_INTERFACE_INFO of axi4lite_clk_i : Signal is "xilinx.com:signal:clock:1.0 axi4lite_clk_i CLK";
Other way is simply drag and drop your axi4lite_m_w.vhd on to bd and see if module referencing flow helps
dpaul24
@DrSAB,
Will try.Thanks
@vsrunga,
The X_INTERFACE_INFO didn't help. K got the same message.
Then I tried your other suggestion - Other way is simply drag and drop your axi4lite_m_w.vhd on to bd and see if module referencing flow helps
It works but keeps the axi4lite lite signals separated. I know I can connect them one by one and BD should pass validation. But that is not my intention, I want to keep the axi4lite signals as a group, keeping the clk and reset separate. How to achieve that?
vsrunga
Can you crosscheck your RTL against "Inferring AXI Interfaces" from this UG ?
If that doesn't help please upload your axi4lite_m_w.vhd to take a look..
dpaul24
@vsrunga,
