CRITICAL WARNING: [BD 41-1287] Associated interface by name **** not found for clock port ****
Hi everybody,
I'm having some issues after deleting and renaming some interfaces from a BD. After these modifications I have a lot of messages like this:
 CRITICAL WARNING: [BD 41-1287] Associated interface by name Dataout_I_0 not found for clock port /I_Clk_DDS
In this case I got this message after renaming Dataout_I_0
I've checked everywhere and I couldn't find this interface.
Nevertheless the project works fine, I can generate the bitstream without problems.
How can I erase these old interfaces?
Mariano
Re: CRITICAL WARNING: [BD 41-1287] Associated interface by name **** not found for clock port ****
Same here.
I associated a clock w/ some IP that was later removed.
There is nothing in the clock's properties to remove.
Did you find a solution?
Emmett
Has anybody figured out how to fix this?   I am seeing this myself now in Vivado 2017.4 in a Kintex 7 project on Windows 10 after I removed interfaces from the block design (see image below).
Tim
I never found a solution.
It doesn't seem to cause a problem, but I would like to clear the warnings.
Emmett
@emmettbradford,
   Xilinx helped me find a solution.   Please see my post at the link below.
Re: Block design giving BD-41-1287 errors
Tim
I looked and looked for that.
I just needed to expand the box and there they were.
Emmett
