Can you set Vivado to run off amazon corretto?
The Computer admins at my Organization of removed Java from our computer systems.  Without Java Synthesis and other vivado functions will not operate.  How can I tell Vivado (2019.1) to use Corretto?  I know Vivado was not written to use Corretto but its all I have at the moment.
Hello @electricflow ,
I won't have an answer about Vivado and amazon corretto, however, from Vivado 2018.3 onward, Vivado uses and comes with Java version 9. This comes with the installation and Vivado will look for the Java version from within its own installer (e.g. /Xilinx/Vivado/2019.x/tps/lin/jre/).
So, if your specific Java version on your machine was removed, when using Vivado 2019.2, it will use Java version from within its own install area, as indicated above.
FYI - Java SE 9 is currently a supported version of Java for Vivado 2019.2
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hope this helps.
Kind Regards,
Anatoli Curran,
Thanks,  IT did verify it was using this Java.
The problem ended up being they had restricted access to Jscript.DLL.   The restriction was not allowing me to synth any design.
