Cannot connect vcse_server in vivado 2013.4
Hi everybody, i am trying to do the labs in ug940 guide.  After generated the bitstream and exported hardware to SDK, i
start to do the lab2.  I download the bitstream successfully, and then try to open the hardware target, but when i connect
the vcse_server, it stopped at the following post. (Over an half hour, it still can not go ahead).
Does someone can give me some suggestions, and i would be very appreciate!
Best Regards,
Dec
Re: Cannot connect vcse_server in vivado 2013.4
Which OS are you working up on?
Is the board connected locally?
Deepika.
Deepika.
Hi Deepika,
I am sorry that my reply is so late and many thanks for your reply!  Actually, i had solved this problem from this thread (
http://forums.xilinx.com/t5/Design-Tools-Others/ERROR-Labtools-27-1829-vcse-server-failed-during-internal/td-p/351763
). I should run the vcse_server in the ISE Command Prompt to start the server first and then open the hardware session
in Vivado GUI.  Now i can connect Vivado cse_server successfully.
Best Regards,
Dec
Hi Dec,
Good to know that you were able to overcome the issue.
Please mark your previous post as Answer. This will help other forum users.
Deepika.
Deepika.
Observer rforsyth
I had this problem and also some errors (cannot open vcse_server) when opening the server in the Vivado Hardware manager.
Closed Vivado, cycled my development board, still occurred
I fixed it by simply ending the vivado and vcse_server processes in the task manager, then restarting Vivado and the hardware manager.
