Cannot generate test bench file
While attempting to generate a test bench file, no file is created. If i aim for a tbw file a console message saying 'Started : "Creating Tbw file".' would appear but no file would be created. If i opt for VHDL Test Bench file I get no messages at all, and, of course, the file is not created.
Note that this problem occurs only when I try to associate the test bench files with an entity containing references to other entities. Should I try the same procedure for simple entities, I have no problems whatsoever.
Thanks in advance.
Edit: I'm using Xilinx ISE 10.1.03 on Win XP SP2.
Message Edited by dusan.stamenkovic on 03-06-2009 01:17 PM
Re: Cannot generate test bench file
I have the same problem over here.
 I try to add a test Bench to my .sch but i only get the message:
And nothing happens.
Any solutions about that?
cheers  :)
