Cannot open synthesized deisgn
Hi I'm getting an error trying to open synthesized design
WARNING: [Runs 36-115] Could not delete directory 'C:/Andy/Project/project_3_zed/.Xil/Vivado-3812-user-sdl/dcp19'.
ERROR: [EDIF 20-89] Cannot open file 'C:/Andy/Project/project_3_zed/.Xil/Vivado-3812-user-sdl/dcp19/design_1_axis_top_NLR_0_0.edf'.
These are the error messages
I've already tried
1. turn off antivirus and reset synthesize
2. deleting vivado and install again
3. move file directory from C:/Users:/users.... to C:/Andy....
and nothing works :)... can anybody help me?
Hi @woody_24 ,
Could you delete the directory C:/Andy/Project/project_3_zed/.Xil/Vivado-3812-user-sdl/dcp19  manually? And then ren-run the project to have a try.
I deleted .Xil file and run synthesize again, but there is still a same error...
So can you generate a example design and run synthesis to have a try? I want to know if it caused by your project. You can also post your project, I will check it on my end.
