urodacus
Change of custom IP in a block design
I'm kinda new to BD and IP but I learned how to use it a bit for a design on Zynq.
If I'm here it's because I encountered a problem. I'm working on a project where the client change some aspects about what he wants so I have to adapt it.
I use a custom IP in a BD and when I upgrade it there is no problem except when the number of ports changes, Vivado ask me to upgrade it so I do but the synthesis won't go through, several error messages (one for each new port).
"Does not have matching formal port for component..."
I deleted the VHDL wrapper and asked Vivado to do it again and still the same. Is there a way to update it without any problem ?
Sorry for bad english and thanks :)
dpaul24
@urodacus,
Yes, if there are unconnected ports of the IP, then Vivado will complain.
Did you try the validate block design feature after your changes to the custom IP?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
urodacus
@dpaul24 I connected all the new ports and design is validated
dpaul24
@urodacus,
From you description I cannot guess any answers.
As a workaround, take you custom IP completely out of the BD. Create a wrapper_BD without your custom IP. Then create a top level wrapper where you instiantiate the wrapper_BD, custom IP and connect both.
anusheel
@urodacus
Did you change custom IP? If yes, please check whether you are able to synthesize(standalone) it or not.
Also, while generating wrapper did you try using "Let Vivado Manage ..."?
Anusheel
urodacus
@dpaul24i don't really know how to do that (excepted manually but that could take some time since if I remember correctly the signals from BD don't really have explicits names)
@anusheelYes I updated my IP :
changed the IP, synthetised it, re-saved it as if it was a new IP but I overwrited previous IP (i don't know if it's automatic so I did that).
I also let vivado manage and update the wrapper.
I had the same issue with the last time I tried updating an IP and I had to create a new project and instantiate it again in a new project since deleting it and instantiating again in the same project didn't work.
Sorry for the time I took to reply and thanks.
anusheel
@urodacus
Are there any warnings or errors reported at the time of upgrading the IP? If not, can you please share a small test with us.
Anusheel
dpaul24
@urodacus,
As it is an alternative solution, it has its merits and demerits. Which solution you choose is your decision.
urodacus
@anusheelI think I found the solution. the .vhd in my project (with the BD) are not updating correctly. If I create a new component in my IP porject, it shows but the one already existing won't update so i copy/pasted the new ones (with new ports), it seems to work.
Now I got a problem with SDK, the peripheral drivers aren't updating in my project but that's another issue i guess.
