slipknotchik
Choosing memory parts issue while generating DDR4 controller
Hello!
I want to generate DDR4 controller for MIG 2.2 in Vivado 2018.2 for DIMM M393A2K40CB2-CTD or HMA82GR7AFR4N-VKT using xcvu9p FPGA. But there are no such chips in MIG configuratrion window for 'memory part'. Where can I get them?
gabed
Hi @slipknotchik ,
To use memory parts which are not available by default through the DDR3/DDR4 SDRAM Vivado IDE, you can create a custom parts CSV file, as specified in the AR: 63462. This CSV file has to be provided after enabling the Custom Parts Data File option. After selecting this option, you are able to see the custom memory parts along with the default memory parts (PG150).
Cheers
Cheers
gabed
Hi @slipknotchik ,
Cheers
Cheers
