naveen_s
Combination Logic Validation failed in Block design
Hi All,
        I have designed a custom multiplex logic in RTL and created a IP out of it. When I tried adding that IP to block design and validate it throws the following error.
 [BD 41-967] AXI Interface Pin /FER_0/ONE_F1_m1_axi_rx is not associated to any clock pin. it may not work correctly.
 More details are given in the Screen shot attached. PFA
Naveen S
syedz
@naveen_s,
From the error message it looks like m1_axi_rx interface of your custom IP doesn't have a clock interface defined. Please note that it is mandatory to associate/define a clock & reset for any AXI interface.
Edit m1_axi_rx interface in IP packager and define the associated clocks to over come the warning.
--Syed
watari
Professor
Professor
Hi @naveen_s
AXI interface is required at least one clock port.
So, vivado said "[BD 41-967] AXI Interface Pin /FER_0/ONE_F1_m1_axi_rx is not associated to any clock pin. it may not work correctly."
Would you refer AXI interface specification, if you want to know detail ?
Best regards,
anatoli
Hello @naveen_s,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
