gerstr
Connect more than one custom IP-Cores to an interface
Hello!
I am using VIVADO 2016.4.
I have generated a custom interface. In master mode there are only outputs, in slave mode only inputs.
I also generated some custom IP-cores. One of them uses the previous mentioned interface in master mode and two of them in slave mode.
After importing these three IP-cores into my block design, I cannot connect both slaves interfaces to my master interface. There is only one connection possible.
How can i connect both ore more IP-cores?
Thank you and best reegards,
Gerald
stephenm
Can you share a screenshot please?
gerstr
There is one IP block, its kind of a register map with an interface with all register settings as output. The other 2 IP blocks have the same interface but in slave mode to get all the registers they need.
stephenm
What interface is this? is it an AXI interface? or a custom interface? Are you trying to connect the same slave to two masters at the same time(if so use a axi interconnect).
If a custom interface, you could just connect signal to signal as a workaround
gerstr
It is a custom made interface.
This Interface was made to reduce the number of connected signals in my blockdesign.
Is there no possibility to connect a custom made Interface to more than one   Slave?
stephenm
Not really. Even if this was AXI Interfaces, you would need to use an AXI Interconnect. You can create a custom bridge with one master and two slave ports, and in the custom bridge RTL you can split them here.
This is one way, other users might have other tips
