Connection Automation failed with a simple MicroBlaze design - VIVADO 2014.2
Hi Gents,
I am using an Ubuntu 14.04 LTS with Vivado 2014.2. I am developing with a ZedBoard revision d. Unfortunately I am not able to set up a simple MicroBlaze design because of this error:
ERROR: [#UNDEF] conversion to double from string is failed
unexpected "," outside function argument list
in expression "1000 / 10,000"
This error occures when I add a MicroBlaze to my empty project and either run the "Connection Automation" wizard or add a Clocking Wizard IP.
This error does not occur in Windows 7 with same Vivado version. Does anyone have an idea how to get rid of this error?
Thank you
I guess the problem is because of using comma (,) as decimal seperator. Try changing the system language settings to US English and see if that helps.
Refer to this article for similar issue http://www.xilinx.com/support/answers/51331.html
Deepika.
Deepika.
Deepika.
Deepika.
Hi @spartiat
Did that work?
Deepika.
Deepika.
Anonymous
Not applicable
Hi I am using Vivado 2014.4 with a zc706 board. When I try to run the Block automation for a Microblaze component, it gives the following error "
[BD #UNDEF] Error occurred while initializing 'clk_wiz_1'
Tcl error in update procedure while setting value 'MMCM' on the parameter 'PRIMITIVE'. unexpected "," outside function argument list in expression "1000 / 10,000"
The default language is deutsche on the computer.
The interesting thing is that the same error does not occur on another computer with deutsche as the dafault language. please help. Also is there any workaround for this?
Anonymous
Not applicable
Hi, I have the same error that the previous poster. I saw the AR #51331, but I didn't understand which file is the " Vivado startup script", where is it?
I have the same problem here on the 2014.4 version, and i can't fine this " Vivado startup script".
Did someone finally find it?
thanks
The vivado startup script is INSTALL_DIR/Vivado/2014.4/bin/setupEnv.sh. Adding the lines shown in AR# 51331 works fine.
Thanks, this fixed the problem for me.
Cheers!
