Constraining communication interface
I'm having difficulty constraining (in .xdc) my pins for communication interfaces in general (SPI and IIC at least). For example, in my Block Design, I created an Interface Port of type spi_rtl. I connected that interface port to the AXI Quad SPI IP in my Block Design. Now, my interface is composed of the following signals:
adc_spi_io0_i
adc_spi_io0_o
adc_spi_io0_t
adc_spi_io1_i
adc_spi_io1_o
adc_spi_io1_t
etc...
What puzzles me is the _i, _o and _t for each IO. I'm don't know how to write, in my .xdc, that this io0 will be used as MOSI. Will this be the correct way to go (and I ignore the _i and _t pins?):
set_property PACKAGE_PIN C16 [get_ports adc_spi_io0_o]
set_property IOSTANDARD LVCMOS18 [get_ports adc_spi_io0_o]
Mentor
Mentor
Re: Constraining communication interface
Hi dt_novo
If the design has a communication interface via Quad SPI, you describe the constraint for input and output.
I guess "adc_spi_io*_i"  is for input and "adc_spi_io*_o" is for output and "adc_spi_io*_t" is for control of output buffer.
I describe the example for it.
Please modify it by yourself.
[example]
- Input
set_input_delay -max <maximum value> -clock <related clock> <port name>
set_input_delay -min <minimum value> -clock <related clock> <port name>
- Output
set_case_analisys <1 or 0 (Enable output mode)> <control pin of output buffer>
set_output_delay -max <maximum value> -clock <related clock> <port name>
set_output_delay -min <minimum value> -clock <related clock> <port name>
[note]
I guess you need to add "-clock_fall" option. But it's related with your design.
Thank you.
Best regards,
thanks for your answer. This, combined with the following link I found, I think I have all the elements to needed!
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=34851
