Core Generator Transceiver Wizard
I am trying to use the transcever wizard for a 7 series device. I want to generate a SATA design but it doesnt seem to be there. I have used it for previous generation FPGA devices so I am a bit surprised it has gone. I suppose I could try and work out the values but it would be easier if it was just available. Anyone know if it will be added?
Re: Core Generator Transceiver Wizard
Yes,you are right.
The 7 series transceiver wizard doesn't have the SATA protocol selection and has a road map to include it in the future release.
Currently it is tentatively shceduled to be included with 2014.1 Vivado release for GTH.
Satish
