Core Generator not generating .sym file
I'm trying to generate a FFT module. I created a new Core Generator project with the "Design Entry" option at "Schematic". In "Flow Settings", I select "ISE" for "Vendor".
The I selected the FFT 7.1 IP, configured it and I generated the outputs. According to the Help, I should have a .asy file and a .sym file generated because I chose "Schematic" and "ISE". But, the files I get are:
xfft_v7_1.asy
xfft_v7_1.gise
xfft_v7_1.ngc
xfft_v7_1.vho
xfft_v7_1.xco
xfft_v7_1.xise
xfft_v7_1_flist.txt
xfft_v7_1_readme.txt
xfft_v7_1_xmdf.tcl
I have no warnings, no errors. Why this isn't working?
Thanks!
Oh and for the record, I'm using ISE WebPack 13.1 on Win 7 64 bits.
Can you post your .xco file please.
