CoreGenerator: Problem generating DCM for Spartan-3 xc3s1000 with ISE13.2
I need to create 2 different DCMs for a project with Spartan 3 xc3s1000-5ft256.
If I use the CoreGen with ISE 13.1, In FPGA Features and design / Clocking / Spartan-3 there is a module Single DCM
version13.1.
Identifier:   xilinx.com:ip:dcm:13.1
Indicated as being supported for my family. The generation is OK, files are generated
BUT
When reloading the CoreGenerator, the module is eliminated and the following indicated:
ERROR:sim:879 - Part 'xc3s1000-5ft256' is not valid for component 'xilinx.com:ip:dcm_sp:13.1'.
WARNING:sim:863 - Failed to create component instance for XAW file 'Z:\projects\fgc\hw\pops\PAL\PAL_6M\FPGA\xproj\DCM_Slice.xaw' during project migration.
And is trying to compile, TRANSLATE fails with following error:
ERROR:NgdBuild:604: - logical block 'PAM_Clock_gen/DCM_INST2' with type 'DCM_Slice' could not be resolved. A pin name misspelling can cause this, a missing edif or ngc file, case mismatch between the block name and the edif or ngc file name, or the misspelling of a type name. Symbol 'DCM_Slice' is not supported in target 'spartan3'.
How can I generate a DCM for Spartan-3?????
PS:I have an old file (vhd) generated with Architecture Wizard (perhaps ISE 9) that is compiled correctly....
Of course I could use the same vhdl and adapt the multiplier / divider for my new cases , but .........
Re: CoreGenerator: Problem generating DCM for Spartan-3 xc3s1000 with ISE13.2
This issue has been identified and currently there is a Change Request to have developers look into and resolve the issue. There is also more information linked below containing suggested options.
http://www.xilinx.com/support/answers/38170.htm
Please read this Answer Record for more information.
Please don’t forget to reply, kudo, and accept as solution!
Anonymous
Not applicable
Did you find a resolution to this issue?
I have something very similar with a Startan 6 DCM.
Unfortunately not... I have patched my old VHDL file instead ....
