Observer tamas.gyorfi
Coregen - generate simulation model only
I'm interested if it's possible to generate the simulation model of a core using Core Generator, without generating the netlist file.
Thanks in advance,
Tamas
Professor
Professor
Re: Coregen - generate simulation model only
If you only want the behavioral models, they already exist in the XilinxCoreLib library.  The structural
models are built along with the .ngc file during synthesis of the core.  The VHDL or Verilog simulation
files generated by CoreGen during customization (for behavioral models) are usually just a wrapper
around the library models.  If you generate the core once, you will find the name of the library model
in the wrapper file, and you will be able to see how the core customization was translated into
parameters (Verilog) or generics (VHDL) in the library model instantiation.  You could then edit
this file to change parameters you want until you are happy with the simulation.  Obviously if you
want to build hardware when you're done, you'll need to re-customize the core with the values
you changed, and re-generate it.
-- Gabor
-- Gabor
Teacher rcingham
Why?
If you really, really, don't want the netlist file, you could always delete it off the disk...
It would save design time when Core Generator is run only for simulation purposes.
Professor
Professor
-- Gabor
-- Gabor
