[Coregen][selectIO] Failed executing Tcl generator.
I use ISE 13.2 under linux and i want to generate deserialization structure using selectIO in coregen.
But when I double clic on «selectIO Interface Wizard» option I've got this following error in popup :
The following error occurred: Failed to generate 'selectio_wiz_v3_2'. Failed executing Tcl generator.
And this error in TCL console :
ERROR:sim - Unable to evaluate Tcl file:
/opt/Xilinx/13.2/ISE_DS/ISE/coregen/repository/xilinx.com/generators/customization_generator_v1_0.tcl
ERROR:sim - Failed executing Tcl generator.
Is somebody know this error ?
Which linux? Some are supported, but not all...
Got same error here but with dist memory generator for Spartan-3AN creating a single port ram 8 x 256
Any workaround?
Thank you!
similar case:clock wizard fails with "Unable to evaluate Tcl file"
software versions: ISE 14.6 on Debian 7.1
solution: edit "settings32.sh" and add xxx/14.6/ISE_DS/ISE/sysgen/lib/lin/ to LD_LIBRARY_PATH , where 'xxx' is the path of your local Xilinx installation
debug method used: run 'strace -f ise 2>/tmp/log' and find 'SIGSEGV (Segmentation fault)' line of child process, replace ISE_DS/ISE/bin/lin/_ipguilauncher by shell script to get commandline arguments, run _ipguilauncher in gdb, notice "0xb1a2b2e5 in QFontPrivate::~QFontPrivate() () from /usr/lib/i386-linux-gnu/libQtGui.so.4", look for Xilinx supplied libQtGui , set LD_LIBRARY_PATH to include Xilinx shared lib, - eh voila. Rather easy, really...
conclusions:
a) Xilinx faces a problem with the vatious shared lib versions, ok, that's understood, shared libs can be a notoroius headache. However, Xilinx might just have looked into this old posting and figure this out themself, IMHO. Saying "not a supported distribution" is missing the point. Other binaries (think Firefox et al) work on different Linux distros too.
b) logging a bit more information will ease life for everyone. Not checking for failure of a child process is sub-optimal C coding. As others have already noticed, the error message is misleading.
c) When leaving the Xilinx namespace, e.g. when calling an installed browser from within a XIlinx tool, the calling program *must* reset the Xilinx specific LD_LIBRARY_PATH environment variable. Otherwise the non-Xilinx programs won't work.
thanks for comments if someone from Xilinx reads this,
best, Peter
hello trogly
I'm getting the same on 14.7 on unsupported Gentoo, I tried your ld library path but it hasn't worked.
I start coregen new project block memory generator and when I click on customise and generate I get the failed executing Tcl generator, this is in the shell:
WARNING:coreutil - couldn't open
   "/home/billy/FPGA/vga80x40/tmp/_cg/_dbg/xil_2.out": no such file or directory
       while executing
   "open ${outFileName} r"
       (procedure "::xilinx::GeneratorUtils::readOutFile" line 17)
       invoked from within
   "::xilinx::GeneratorUtils::readOutFile $componentInstanceID $outFileName"
       (procedure "main" line 40)
       invoked from within
   "main $argc $argv"
       invoked from within
   "return [main $argc $argv]"
       (file
   "/opt/Xilinx/14.7/ISE_DS/ISE/coregen/repository/xilinx.com/generators/customi
   zation_generator_v1_0.tcl" line 58)ERROR:sim - Unable to evaluate Tcl file:
   /opt/Xilinx/14.7/ISE_DS/ISE/coregen/repository/xilinx.com/generators/customiz
 There is a xil2.in in that directory :) .
Any help out there?
