Visitor dlisi_src
Create Custom IP - VHDL2008
I created a project to package it up as a custom IP and all of my VHDL files are set as VHDL 2008. When I package the the project up I get warnings for all of my VHDL files in the File Groups Packaging Step:
[IP_Flow 19-991] Non-synthesizable or non-simulation file 'xyz/xyz/xyz.vhd' found in file group 'Synthesis'. You may want to add it to the xit utility file group.
The type of each file is vhdlSource-2008 (auto-populated). If i change that to just vhdlSource the warning goes anyway.
I'm using Vivado 2016.1. I've built and tested the same code in project flow just fine, I'm just trying to package it up now. Any ideas?
Re: Create Custom IP - VHDL2008
Hi @dlisi_src,
Can you try to do a TOP_LEVEL of your design in VHDL (not VHDL2008)?
I think there is currently a limitation when packaging an IP with a top level in VHDL2008.
Florent
Florent
Visitor dlisi_src
Thanks for the quick reply @florentw
I created a new TOP_LEVEL as just VHDL instead of VHDL2008. It's just a wrapper that instantiates my old TOP_LEVEL - I think that's what you suggested I do.
I'm still getting all the VHDL2008 related warnings. The project packages up just fine using either TOP_LEVEL. I'm just not convinced it will work or synthesize properly.
Can you share your project, or a small version to reproduce the issue?
Florent
Visitor dlisi_src
I can't share my exact project, but I made a test project with essentially the same make up. I marked a few files as VHDL 2008 and the rest, including the top, as normal VHDL.
If you go to package the project, you'll see the warnings about the VHDL2008 files.
Observer redted
Push: As I can't get this to work in Vivado, even the mentioned method of adding vhdlSource-2008 (which is not in the specifcation of file types of spark 1.0, which Xilinx uses) makes the files of the IP appear as VHDL files, rather than VHDL 2008 files. (And yes I do get Syntax errors on VHDL 2008 syntax)
