Create HDL Wrapper - Differential Signals are std_logic_vector. Want std_logic.
When I Create an HDL Wrapper the "differential" signals are created as:
std_logic_vector(0 downto 0);
Is there any way to have them created as std_logic?
Swimteam
Re: Create HDL Wrapper - Differential Signals are std_logic_vector. Want std_logic.
What if found was when instantiating the wrapper use the syntax:
refclk_p(0) => refclk;
where refclk is a std_logic;   No problems with this. I think this is better than editing the wrapper file and changing all std_logic_vectors to std_logic.
Swimteam
You can create an HDL wrapper of the generated wrapper and add it to your project source files.
--Sebastien
Teacher drjohnsmith
the tools are 'generic' / macro driven,
     and evidently, Xilinx are not very hot at VHDL, as they use Verilog for most things.
So the tools generate a std_logic_vector( X-1 downto 0 )
    and if X is 1, for a single bit, the tools make std_logic_vector( 0 downto 0)
Its a real pain. thing slike fifos that we use a lot, have single pins that are std_logic( 0 downto 0)
So you end up doing a lot of fred <= fred_slv;
where fred is std_logic and fred_slv is std_logic_vector( 0 downto  0)
If your using VHDL 2008, it might be worth trying type casting std_logic( fred_slv), neve rtrie dit , but its a thought
dont hold breath for xilxin to improve the IP, we have been on at them for decades, litraly since before ISE,
Swimteam
