Visitor mavoro
Create and Package IP - Compatibility Window doesn't load
I'm trying to create a simple IP package. I follow a tutorial, so I'm stuck at the IP packaging step "Compatibility" where I'm supposed to add the device family for compatibility as shown in the picture.
The problem is, it is not possible to add a family type at all. It says "IP component is being reloaded. Please wait..." (see picture below) and no matter how long I've waited, it wouldn't load.
What is the problem? Is it even relevant, or can I skip this step?
(The Tutorial I am following is https://reference.digilentinc.com/learn/programmable-logic/tutorials/zybo-creating-custom-ip-cores/start)
Community Manager
Community Manager
Re: Create and Package IP - Compatibility Window doesn't load
Hi @mavoro ,
Are you able to relaunch Vivado and try once again?
Thank you,
Devin
Community Manager
Community Manager
Hi @mavoro ,
Thank you,
Devin
Participant sjg69
I see this as well, after editing the IP. Relaunching Vivado fixes it.
