Participant orenderj
Custom IP SDK Drivers being placed in Windows\Temp folder
I am generating a few custom blocks from some verilog and when I finish packaging them and use them in my design, I export and start using my sdk as I have done in the past many times. I am on a new laptop with Vivado installed which is the difference between my old setup. When I generate my bsp from my hdf and make an application, none of the drivers are there for my custom blocks like before. I did a search and ended up finding that the IP packager was dumping them in my windows temp folder. Does anyone know how to include them with the exported ip block files?
Re: Custom IP SDK Drivers being placed in Windows\Temp folder
Nothing on this? Where does Vivado decide to put drivers from the IP generator? This cant be an arbitrary folder on my filesystem somewhere.
