el3ctrician
Custom IP inheriting params from used IP
so i have been working on a custom IP that incorporates a BRAM memory inside of it. The IP is made using the Block Design and it uses other IPs that are developed in VHDL. I want my IP to inherit some of the its building blocks parameters, for instance i want to expose the memory init parameter for the BRAM with the relative path to the .coe file.
Can you please give me any directions on how to achieve this ?
