lhzh7
DCM can't generate a correct clock
Hi, I have a problem with the DCM. I set the input clock 100MHz, output clock 133MHz. But the DCM generates the output clock 100MHz in the .v file. I use the ISE 14.3 and win7 64 bit.
lhzh7
  I have solved the problem. It may be  that the ISE 14.3 have some bugs on windows 7 64 bit. I install the ISE 14.7, and the problem has gone.
vuppala
Hi @lhzh7
Which device are you using?
I used Spartan-6 and clocking wizard (DCM primitive) and inputted 100MHz and successfully generated 133MHz. See below for simulation snapshot:
Also attached clocking wizard IP.xco file for your reference.
Vinay
lhzh7
