DCM created from IP core generator won't generate vhd file
This is a problem that has popped up randomly over the past few years and I'm a little sick of it.  If I have an ISE project and I create a DCM with the IP core generator, a .xaw file is created.  If the situation ever arises where I have to do a project cleanup, the vhd files associated with the DCM go away (as expected).  however, they never come back.  what can I do to make the vhd files come back without starting a new project??
the solution is to use Coregen to make the files.
regenerate the .vhd file using the xaw file
Historian
Historian
The better solution is to instantate the DCM by hand. It's really not that difficult at all, and your project won't get screwed up when the tools change.
-a
