DCM
Can i use DCm to generate clock of 16 KhZ for my application? let me know how to configure DCM for a particular freq?....... If not let me know nay other options
The Input and Output frequency that can be obtained from a DCM would depend on the device(FPGA).
To get familiarized with DCM, you can refer to XAPP462 http://www.xilinx.com/support/documentation/application_notes/xapp462.pdf
This is with reference to Spartan-3 but is applicable for other FPGA's as well.
HS.
