JKdevelloper1
DDS compiler with an output higher than its input
Hi, I am using DDS compiler to generate IQ data. As I know the output frequency of the dds should be small than the input freqeuncy. They is any possiblity to generate an output frequency higher than the input. How can I multiple DDS in parallel. for example I have 1000 MHz input and 30000 MHz in output. Please any explication. Thanks a lot.
