Observer joseraul
DSP48 macro in SIMD mode
I need to perform additions of 8-bit + 8-bit, 16-bit + 16-bit, and  32-bit + 32-bit widths. I want to use  the SIMD mode of the DPS48 slice. I would like to know how to customize  the  DSP48 Macro from the IP catalog from Vivado (v2014.4) to do this.
I have read the LogiCORE IP DSP48 Macro v3.0 Product Guide and the 7 Series DSP48E1 Slice User Guide, however I can figure out how. Please provide some advice.
Raul.
Re: DSP48 macro in SIMD mode
DSP48 macro  IP not support SIMD mode
If you want to take advantage of SIMD mode of the DSP slices, you must instantiate them manually. See attached for an example
Hope it will help
Thanks and Regards
Balkrishan
Scholar pratham
@joseraul Check A+C operation in wizard.
-Pratham
you can try A+C , A+D, C+D . select multiple option and use select line .
Thanks and Regards
Balkrishan
Observer joseraul
Hello Pratham,
A+C operation allows me to perform operations of 2-25 bit wide. However I need to perform SIMD like operations, for example in a 25-bit wide vector i want to perform two independent 8-bit addition operations. Is it possible to customize the DSP48 macro to obtain this functionality?
Raul.
Hope it will help
Thanks and Regards
Balkrishan
Observer joseraul
In other words how to obtain the functionalty of the USE_SIMD option  ("ONE48", "TWO24", "FOUR12")  on the DSP48 macro from the IP catalog.
Raul.
this is not supported in DSP48 macro as i mention above . Check the attached example code. Hope it will help you
Thanks and Regards
Balkrishan
Observer joseraul
I see. Thanks a lot for make it clear, it solved my question.
Raul.
