08-18-2019 08:51 AM
Good day,
My question is more of curiosity nature, please advise on the following if you have an interest.
I am playing with different HDL descriptions of ripple-carry adder up to the level of elaborated design ans synthesis. I follow structural modelling at the gate level with Verilog to describe full adder and then the full adder is used as a building block for the ripple-carry adder modelling.
I model full adder in two ways:
1. With two-level logic in some of products (type 1).
2. And using XOR, AND and OR functions (type 2).
Both models of full adder elaborate to the netlists of generic gates accordingly to descriptions differing only in the types of gates.
Synthesis processes for both models produces equivalent schematic shown below
and it is clear for me - both models describe the same function and the implementation of combinational logic is deployed on LUTs.
On the next step, I am modelling two 32-bit ripple-carry adders in a structural way with previously described full adder models as the building blocks. As result of synthesys, I expected to see equivalent netlists for both RCAs since each of the full adder models resulted in an equivalent netlist. But actually, the resulted netlists are different and occupies different resources.
RCA built with full adder (type 1) requires 146 cells and 211 nets.
RCA built with full adder (type 2) requires 177 cells and 242 nets.
Can you please give me a hint, what why it happens in this way. I would expect an equivalent netlist for both, and if I can set up the tool produce equivalent netlist.
Thank you for your help!
08-22-2019 03:48 AM
Thank you for all your comments and clarifications, they led me to finish my exercise with all goals set up as achieved. I gained deeper understanding of the distinct features of the design flow with FPGA , and I also got quite detailed knowledge of the CLB architecture and the primitives.
08-18-2019 10:30 AM
08-18-2019 10:54 AM
Thank you for your clarification, the situation is less confusing for me now.
I am using Vivado 2019.1
And one more thing that did not mention in original post. The design is relaxed in terms of user specified timing constraints. I simply did not specify them.
08-18-2019 04:57 PM
More importantly - neither of these is the way to implement a wide adder - the proper way is to use the '+' operator.
When using the addition operator, the tools will implement the adder "the right way", which is using the built-in fast carry lookahead logic built into the CLBs. This will be significantly faster and smaller than any adder implemented as pure LUT based logic - a 32 bit adder should be implemented in something like 64 LUT5s, which can be mapped into 32 LUT6, taking only 8 CLBs (or something like that) and the dedicated fast carry cells. It appears that the tools are not able to take a low level description of a RCA and realize it is an addition operation and implement it in the fast carry lookahead cells...
I understand if you are playing with the RCA implementations just to see what the tool will do with them, but in a "real" design, you should always use the + operator.
Avrum
08-22-2019 03:48 AM
