Disable block in Vivado block diagram design
I have several blocks in my design which I would like to disable (not delete) from the design so that my build time is faster. Is there an easy way to do this from the GUI or by editing the hdl that doesn't break the block diagram view? Thanks
Scholar pratham
Re: Disable block in Vivado block diagram design
cepope@nc.rr.com No, There is no way to do this either
-Pratham
Scholar pratham
cepope@nc.rr.com Select the BD you wish to disable and right click disable.
shortcut is  ALT + MINUS
Through TCL
Example
set_property is_enabled false [get_files design_2.bd]
-Pratham
Hi cepope@nc.rr.com,
Use the following TCL command:
set_property is_enabled false [get_files  <project_path>/bd/design_2/design_2.bd]
In Vivado GUI. Select the block in File hierarchy and right click to Select Disable file as shown below:
--Syed
If you are asking for method to disable IP within block design then there is no such option provided.
Deepika.
Deepika.
Yeah, I see that an entire .bd file can be disabled but I am trying to disable a block within a .bd file leaving the other blocks alone. According to this last answer that isn't possible? Maybe there's a way to export the block(s) I want to disable as .bd files, while keeping the heirarchy, and then disable them? Thanks
Scholar pratham
-Pratham
Visitor dmatkin
Is there any plan to add this feature in the newer editions?
This seems like it wouldn't be a significant addition and it would help when developing large projects where the synthesis time gets to be stupidly large. Especially when certain elements have issues meeting the timing constraints.
Observer intriple2018
I would very much like to see this option implemented in Vivado as well.
Observer hitec100
Disabling rather than deleting a block in a block diagram would be very much like temporarily commenting out a component in VHDL. In VHDL, this is done all the time -- comment this out, comment this in.
This is a feature that is long overdue in IP Integrator.
