analogital
Doc Navigator display bug
as figure show doc nav do not show any text ,how to fixed this problem ?
tiantian
watari
Professor
Professor
Hi @analogital
It seems font issue on PDF veiwer.
What OS are you using ?
analogital
Hi @watari I'm use windows10 Workstation Edition and doc Nav use default setting.
watari
Professor
Professor
analogital
Hi @watari
I already refer this post ,but it's no help. thank you.
anatoli
Hello @analogital ,
You may want to contact Tiantian, as she is our DocNav developer and the support expert. She has dealt with the issue in the above link and her email is also provided in that thread. @tiantian should be able to advice further on your issue then.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
tiantian
anatoli
Hello @analogital ,
This topic is still open and is waiting for you.
Is the suggestion in the last reply helped you with your issue?
If your issue is not solved yet, please reply in the thread, so that we can further assist you with your issue.
However, if your question is answered and/or your issue is solved, please mark a response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.  We appreciate your help.
Kind Regards,
Anatoli Curran,
Versal Blogs
analogital
hi,@tiantian its sloved my problerm,thank you.
