olivierporchy
Hello
I have an error message about a Product Guide that is not found when I try to get it by a right click from the Vivado IP catalog, whereas the document is in DocNav as you can see in the enclosed print screen.
Anybody could help on this (little) issue ?
Olivier
florentw
HI @olivierporchy
So if I am understanding correctly, you are getting this issue from Vivado when you click on the DDR4 MIG controller. Correct?
I have reported the issue but it will not be possible to fix this for released version (and 2020.2 will probably have the same issue as this might be too late for a fix)
I guess you will have to use DocNav (or Xilinx.com) to get the doc
Florent
florentw
HI @olivierporchy
Florent
