Observer he2304
Docnav on Ubuntu 18.04 LTS
I've installed Vivado 2019.1 on Ubuntu 18.04 LTS and it's running just fine.
However when I try to start docnav i get the following errors:
Gtk-Message: 08:38:25.431: Failed to load module "overlay-scrollbar"
Gtk-Message: 08:38:25.431: Failed to load module "appmenu-gtk-module"
Gtk-Message: 08:38:25.431: Failed to load module "gail"
Gtk-Message: 08:38:25.431: Failed to load module "atk-bridge"
Gtk-Message: 08:38:25.432: Failed to load module "canberra-gtk-module"
(docnav:7958): Gtk-WARNING **: 08:38:25.656: Unable to locate theme engine in module_path: "murrine",
I've checked and as far as I can tell, all those packages are installed.
So what am I missing?
Re: Docnav on Ubuntu 18.04 LTS
You can also try these suggestions from askubuntu:
https://askubuntu.com/questions/823871/gtk-warnings-while-installing-and-or-starting-up-vmware
Cheers
Hi @he2304
Checkout this forum and try some of the suggestions: https://forums.xilinx.com/t5/Design-Entry/IP-Documentation-Won-t-Open-in-Vivado-2019-1-1-on-Ubuntu-18-04-2/td-p/998875
Cheers
Observer he2304
That link didn't help, cause I don't get an ssl error I get gtk errors.
Cheers
