Does Vivado support IEEE P1735 encrypted RTL IP by Synopsys VCS?
VCS support -ipprotect protect_header-file to encrypt IP in IEEE P1735
But it need Xilinx Vivado public RSA key in encrypt flow.
Or how does IP vendor encrypt RTL IP in IEEE P1735 format to Vivado?
An IP provider retrieves public keys for an EDA tool from its documentation. For VCS it is this section on IEEE Verilog Std 1364-2005 Encryption. For other tools an IP provider might need to contact its vendor.
The protection_header_file that this example specifies with the -ipprotect option is in Example 25-2.
Example 25-2 Example Protection Header File for Source Encryption with VCS
Re: Does Vivado support IEEE P1735 encrypted RTL IP by Synopsys VCS?
Hi jason.tsai@orisetech.com
Check the section "IEEE 1735 IP Encryption and Rights Management" in the following link: http://www.xilinx.com/publications/prod_mktg/ipcenter/Plug_and_Play_IP_backgrounder.pdf
Vinay
Dear sir,
I have check this documents yet.
>Check the section "IEEE 1735 IP Encryption and Rights Management" in the following >link: http://www.xilinx.com/publications/prod_mktg/ipcenter/Plug_and_Play_IP_backgrounder.pdf
The Vivado Design Suite 2013.3 leverages the IEEE P1735 standard to provide integrated flows that support verification of
designs containing Xilinx LogiCORE and SmartCORE IP using the Cadence Incisive® Enterprise simulator, the Synopsys VCS®
simulator, the ModelSim® and Questa® Advanced simulators from Mentor Graphics®, and the Xilinx Vivado simulator.
If Vivado support IEEE P1735 by Synopsys VCS, should Xilinx provide your RSA public key to encrypt IP?
Or Vivado Design Suite provide IEEE P1735 encrypt function? Can you guide us where to find this informations?
Thanks you!
Hello jason.tsai@orisetech.com
I suggest you to contact your nearest sales or distributors.
http://www.xilinx.com/about/contact/sales-offices.html
http://www.xilinx.com/about/contact/authorized-distributors.html
Vinay
Teacher muzaffer
Can you tell us what tool supports in Xilinx toolset supports encrypting RTL so that xilinx tools will be able to read? Suppose one has a valid license to Vivado. Is it possible to use it to encrypt a piece of RTL so that Vivado simulator/synthesis can read it properly?
