Visitor felx
Dynamic reconfiguration of DCM_ADV provoke "DO[0] - Phase-shift overflow" error when CLKOUT_PHASE_SHIFT=NONE
Hi, friends,
I use DCM_ADV for dynamic reconfiguration of CLKFX output clock (Virtex5).
The problem is that in my tests (multiple CLKFX reconfiguration to see if it works good) I sometimes get "DO[0] - Phase-shift overflow" error and  DCM_ADV is not locked (LOCKED output= '0')... but I use CLKOUT_PHASE_SHIFT          => "NONE" in vhdl configuration of the DCM_ADV. In documentation it is said that "DO[0is deasserted if the phase shift feature is not used (CLKOUT_PHASE_SHIFT=NONE)".
What can be a problem here with my design?
The following is some information about the DCM_ADV usage in my design.
1) This is generic map: (dont use feedback, phase shift = none, etc. )
generic map(
CLK_FEEDBACK => "NONE",
SIM_DEVICE => "VIRTEX5",
CLKDV_DIVIDE => 2.0,
CLKFX_DIVIDE => 3,
CLKFX_MULTIPLY => 26,
CLKIN_DIVIDE_BY_2 => false,
CLKIN_PERIOD => 25.0,
CLKOUT_PHASE_SHIFT => "NONE",
DCM_PERFORMANCE_MODE => "MAX_SPEED",
DESKEW_ADJUST => "SYSTEM_SYNCHRONOUS",
DFS_FREQUENCY_MODE => "HIGH",
DLL_FREQUENCY_MODE => "LOW",
DUTY_CYCLE_CORRECTION => TRUE,
FACTORY_JF => x"F0F0",
PHASE_SHIFT => 0,
STARTUP_WAIT => FALSE --,
2) CLKIN comes from IBUG and is 40 MHz.
3) I dont use PSEN and PSINCDEC
PSCLK => i_clk,
PSEN => '0',
PSINCDEC => '0',
4) I use dynamic reconfiguration as following (DCLK=100MHz):
4.1) I move DCM to reset for more than 10 periods of  CLKIN (3 is requested in docs)
in reset state:
4.2) for CLKFX = 40..150Mhz I first change DFS_FREQUENCY_MODE to LOW, and second change CLKFX_DIVIDE and CLKFX_MULTIPLY values. Always wait DRDY.
4.3) for CLKFX >150Mhz I first change DFS_FREQUENCY_MODE to HIGH, and second change CLKFX_DIVIDE and CLKFX_MULTIPLY values. Always wait DRDY.
4.4) wait for arond 100 periods of DCLK
4.5) move DCM to work state deasserting reset
4.6.) Wait for LOCKED = 1.
Sometimes (1 of 100-200 times) LOCKED remains 0, and DO[0]=1.
If you have any ideas how to fix the problem, please help.
Felix.
Scholar austin
Re: Dynamic reconfiguration of DCM_ADV provoke "DO[0] - Phase-shift overflow" error when CLKOUT_PHASE_SHIFT=NONE
f,
After anything is changed, the DCM should be reset.
Austin Lesea
Principal Engineer
Xilinx San Jose
