EDIF netlist and external blocks
I'm trying to use an EDIF netlist in Vivado.
The EDIF file uses some logic blocks which are included as "external" and declared / implemented in another file.
The EDIF module is included in a third top module.
This is the hierarchy:
top_module.vhd
    processing.edif
          hal.vhd
The EDIF module uses some modules declared and implemented in hal.vhd.
In processing.edif file, these's a directive referring to external hal.vhd file:
  (external work
    (edifLevel 0)
    (technology (numberDefinition))
    (cell RAM_WRAPPER
and in hal.vhd file:
entity RAM_WRAPPER is
end RAM_WRAPPER;
The synthesis works, but implementation gives this error:
 [Project 1-486] Could not resolve non-primitive black box cell 'RAM_WRAPPER' instantiated as 'inst_top_module/inst_RAM_WRAPPER'
Implementation is not finding the required sub-block for the EDIF module.
Probably there's some error with the name of the library "exported" by hal.vhd and the library name "imported" by processing.edif.
How could I fix this problem?
Andrea
Re: EDIF netlist and external blocks
So, as I'm trying to use a vhd in place of edif file, the answer is that you can't...
Andrea
@andpas,
Can you please share a test case to reproduce the issue?
For such errors, my first debug step would be to check if all the files are correctly added to the Vivado project.
--Syed
Hi @andpas,
  1. Can you please try with Post-synthesis project in case you are using RTL project?
  2. Is the EDIF file name matching the top module name in the EDIF file?
  3. Can you please share the complete steps you are using?
Arpan
unfortunately I can't supply a project, as it contains protected IPs.
The fact is, from my tests, if you add to the project an EDIF referencing to external entities, these entities will work only if they are included in other EDIF too.
If the nested entities are added as VHDL, they are simply ignored.
But if you synthesize the VHDL to EDIF, then you add the EDIF to the project, it will work, but of course it's not very comfortable if you need to change generic parameters on the nested code.
I suppose it's a question of library names...
Any help from the Xilinx technical support?
Andrea
I have similar problem. I have a top edf source file but other .edn files are not showing as sub-hierarchical blocks of this main entity. How can I solve this?
Please have a look into:
For example: IQ_TX_c_addsub... should be under IQ_TX.edf
Looking for hearing from you,
Rodolfo
Hi @andpas. The hal.vhd should be added as another EDIF file, since it is contained within an EDIF. I would also suggest changing the compile order of the implementation to manual based on the following answer record.
https://www.xilinx.com/support/answers/63121.html
Hello @andpas,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Andrea
