ERROR:Portability:3 in PAR XILINX ISE 14.7
Hi All,
My Device Target is XC6VLX550t -2 FF1760.
This is the Error i am getting in PAR Phase Of Implementation and here are the Options for MAP and PAR Phase in my Design thru COMMAND Line.
Command Line :
map -p xc6vlx550t-ff1760-2 -w -logic_opt off -lc off -register_duplication off -ol high -mt 2 -o design_map.ncd design.ngd design.pcf
par -w -mt 4 -ol high -xe c design.ncd design.ncd design.pcf
ERROR:Portability:3 - This Xilinx application has run out of memory or has
   encountered a memory conflict.  Current memory usage is 4078308 kb.  You can
   try increasing your system's physical or virtual memory.  If you are using a
   Win32 system, you can increase your application memory from 2GB to 3GB using
   the /3G switch in your boot.ini file. For more information on this, please
   refer to Xilinx Answer Record #14932. For technical support on this issue,
   you can open a WebCase with this project attached at
   http://www.xilinx.com/support.
W.Deepak
回复: ERROR:Portability:3 in PAR XILINX ISE 14.7
Are you using Windows 32-bit OS? The error is saying that the PAR process has run out of memory.
@deepak_wudali,
Make sure you are using supported OS with ISE 14.7
https://www.xilinx.com/support/answers/18419.html
--Syed
I am using centos 64 bit OS linux. Does this not supported??
This Error has nothing to do with implementation and just relies on correct OS to be installed?? Please confirm
W.Deepak
@deepak_wudali,
Yes, Centos is not supported with ISE 14.7. Using unsupported OS could be one of the many reasons for such errors.
You also need to check if you have machine has sufficient memory to run the application.
--Syed
Hi @deepak_wudali,
Did you get a chance to debug this further? Is there any update you would like to post?
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
