ERROR: [Project 1-161] Failed to remove the directory in vivado ip packager
Hi, all
When I was using Vivado 2019.2 IP Packager to package an IP, I got the error:
ERROR: [Project 1-161] Failed to remove the directory './.cache'. The directory might be in use by some other process.
Also, I just can't find this directory under my IP project dir, or my current project dir.
I have tried running Vivado as root, or change to version 2018.3, but the issue is still there. Any help?
EDIT: After some debugging with fswatch, it seems Vivado was trying to delete ~/.cache under my home folder, which will of source fail. Maybe this is a bug or something?
Hi @gaoyichuan ,
You could try to change the working directory to allow the archive to work successfully.
You can refer to this Answer Record.
Please let me know if you still need more assistance.
-Romisaa
