Harjot1
ERROR: [Synth 8-439] module 'xpm_fifo_sync' not found [/work/harjot/jcv0_git/v0/cmfa/rtl/cmfa_event_extractor.v:1098].;ERROR: [Synth 8-439] module 'xpm_fifo_sync' not found
Hello While synthesizing  i am getting below Errors -:
I am using vu5p fpga board .  The Paths of Xpm os already provided in the scrpit file. But still facing the same
1.ERROR: [Synth 8-439] module 'xpm_fifo_sync' not found [/work/harjot/jcv0_git/v0/cmfa/rtl/cmfa_event_extractor.v:1098]
2.ERROR: [Synth 8-439] module 'xpm_fifo_sync' not found [/work/harjot/jcv0_git/v0/cmfa/rtl/cmfa_event_extractor.v:1098]
Please suggest
Harjot
surajc
Hi @Harjot1
Please have a look at the following AR
https://www.xilinx.com/support/answers/67815.html
Harjot1
ERROR: [filemgmt 56-285] srcscanner execution failed with return code 139.
This above is the 1st error i ma getting . Please suggest . Solution for the above Error i am trying and Let  you know  tomorrow Morning wherther it worked or Not.
Please suggest .
surajc
Hi @Harjot1
When exactly did you get this error?
