ERROR: [Vivado 12-3564] The Nested sub-design
When scripting, how do I tell if an ip is a sub-block of an IP or not? (This is not involving a bd file)
reset_target all [get_ips]
ERROR: [Vivado 12-3564] The Nested sub-design '...' can only be reset by its parent sub-design.
(This is got to be one of the stupiest errors I've ever seen in any tool.)
Re: ERROR: [Vivado 12-3564] The Nested sub-design
Hi, @michaellodman ,
Which version of Vivado are you using?
Could you let us know which IP cause the issue?
2016.4
The parent is one of our IPs incorporating a xilinx fifo.
